Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Checking for watts...or amps...
    Jan 2004
    1,667
    There are two heaters on this waste oil furnace that I'd like to find out their power. Of coarse they run on 120V, but how can I check the amps? I do have a VOM, but I think the the fourth gradient is for milliamps.
    take 120 volts and multiply the amps or Ma to get watts
    Aug 2010
    Riverview, Fl.
    293
    You'll need an amp meter to wrap around one of the two legs. If they plug into the wall, you would need something like this to read amperage, wattage and voltage: Electrical Collectible: Home
    if your meter can read 10 amps or less you can insert the meter in series with one element lead to the hot or neutral and read the amps directly. then all you can do is calculate volts times amps for the wattage. a clamp around ammeter is better because there is no hazard of live bare wires. the jaws just clamp around one lead and you read the amps directly off the led readout.
    Jan 2004
    1,667
    Watts...
    Oh! So I can connect the mA scale in series? I thought it was for just micro-sized amperage. Which of the scales should I put it on? The larger number or smaller?
    usually the largest, but if you have a terminal marked 10A the meter will read it directly. that is 10A and the black lead.
    Jan 2004
    1,667
    Amps check...
    I almost tried it today, but thought I'd check with you first. The VOM meter has that part described as DC ma. Then there's the continuity, VDC and of coarse, VAC. Still okay to go ahead and use that DCma range?
    I was leary myself until I tried it, it works
    Jan 2004
    1,667
    Watts?
    Okay then. I'll do that tomorrow. Thanks, HayZee....
    Jan 2004
    1,667
    Watts....
    Not sure watts going on here. I set the vom to each of the gradients on the DC mA scale and each time it pinned the needle to the left with a pretty violent chatter. I also switched the leads so it read from the red side of the VOM and from the black side of the VOM. Rats. Was hoping I could get an amp read. Oh well, on to something else....
