Monitor heater yellow flame
  • Monitor heater yellow flame
    I have just put in new combustion motor bearings and damper o-ring and get a nice blue flame until it goes on high. Is it possible I need to replace the combustion motor?
    Do have Spare motors - wonder if anyone else has run into this?
    burn ring and burn mat are new, the burn pot has been sandblasted so all air holes are clear.
    The monitor is a monitor 41
    monitor
    is there any soot being produced with the yellow flame? I'm assuming you cleaned out the fuel sump in your overhaul process. if you replaced the bearings, why would you replace the motor? it spins up and allows your heater to run in low-med speed.
      what is the pressure differential ? did you forget any gaskets ?
        Motor does spin but wondered if the motor might not be putting out the rpm's.
        Yes I did clean out the sump, have not put my guage on to test the air pressure.
          I will check the pressure. No I did not forget any gaskets
            exhaust good ? air intake ? using correct air intake parts ? standard damper ?
            dont you live somewhere near me ?
              let me know what you get
                Standard damper, good exhaust. Will check air pressure.
                Yes in vt
                  did you figure it out ? what are you using to verify differential ?
                    Not had A chance to put my guage on it - factory air guage (magnehelic ) made by dwyer
                      differential air gauge
                      you don't need something as exotic as a store bought air gauge. a simple 36 inch water column gauge will do. look online there are sites on how to build one. its called a MANOMETER
                        So how did you make out with the heater ?
                          frozen
                          Dan,
                          I think msearcher froze to death.
                            Ha ha,
                            maybe i should go see if he needs thawing
                              Hey msearcher,
                              you still with us buddy ?
                              i know you must have stopped using the unit by now since its 90 outside, well probably inside too we were wondering how you made out ?
