Results 1 to 4 of 4
Thread: Crawl Space Winter Preparation
  1. #1
    Join Date
    Oct 2012
    Posts
    2
    0
    Thanks Thanks Received
    0
    Thanked in
    Lightbulb Crawl Space Winter Preparation
    Hello,I live in the White Mountains of AZ and my home has a vented crawl space. I want to block the crawl space vents for the winter to avoid the cold drafts but I do not have plastic down. Will this cause any issues or will it be ok to do for just the cold months? Thanks in advance...
  2. #2
    Join Date
    Mar 2006
    Location
    North Carolina
    Posts
    1,895
    1
    163
    Thanked in
    Unless your crawl space is "conditioned" meaning heated and cooled with a completely sealed floor area is is unwise to "seal" the airflow. Conditioned crawlspaces have the plastic/visqueen laid over the entire floor area and sealed against the crawlspace walls and piers with either tape or sealing resin, as well they have some sort of heating/cooling to also help reduce humidity etc... Sealing the vents of what you describe in your crawlspace could be very problematic with moisture issues especially with no covering over the dirt floor. How old is the home ?
    Join Date
    Oct 2012
    Posts
    2
    0
    0
    Thanked in
    the home was built in 2007. it has vents built into the block crawl space wall every 10 feet or so. they are adjustable but will not close all the way. I'm assuming this is to choke them down for the winter? Thanks for the info
  4. #4
    Join Date
    Mar 2006
    Location
    North Carolina
    Posts
    1,895
    1
    163
    Thanked in
    Closing the vents is much different to sealing them off for the winter, most often nowadays crawlspace vents are automatic they will open and close automatically depending on the exterior temperature, when closed they still allow a very limited amount of air movement usually enough to alleviate any moisture issues for the winter.
Thread Information
Users Browsing this Thread
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
