Results 1 to 6 of 6
Thread: Vinyl veneer cabinets
    Oct 2013
    Alabama
    Probably has been asked....
    I have vinyl cabinets that are peeling from the heat of appliances in those locations.
    Aggrevating...
    So appears to have particle board under.
    Possible to peel and paint this stuff?
    If so peeling can be done how? Heat gun or steam?
    or Gut these cabinets and sink them for a fish's home. (doubt the fish wants them either)
    8,733
    482
    counter tops
    sure you can peel the stuff off with aid of a heat gun but then that leaves the glue. particle board or mdf medium density fiberboard. the particle board is hardly what you want for a top finish. even if you use a two part epoxy, you are going to have problems down the road. replace with formica.
    Oct 2013
    Alabama
    thanks for the advice.
    iiiiimmmm thinking im scrapping these. I dont see it getting better with the heat sources still being used.
    toaster and oven.
    Thinking i should just go with real wood.
    8,733
    482
    heat ?
    how in the heck did heat ruin your counter tops? unless you placed a hot saucepan on the counter, which I can understand. Why didn't you use a trivet underneath it?
    appliances don't normally direct heat downwards i.e. a toaster, a microwave, a toaster oven
    Nov 2013
    You should always go with real wood as it is one of the best wood which really last for long and best for your cabinets.
    Jun 2014
    17
    Quote Originally Posted by korean1 View Post
    Aggrevating...
    If your good with a power saw you can always reface them. Just buy some lumber, cut your new cabinet doors, sand them and varnish them and then installed them with some new hinges. I am doing this now because I had the same issue with the heat. I'm about half way done, I'll share a pic of them when I'm finished I'm sure you will love it.
