Thread: Cleaning Cement prior to painting
    Dec 2012
    35
    I am painting a 8 x 8 x slab using Stoneffects Rollable paint with primer in it already. I own a power washer and was wondering if that alone is good enough to wash the slab and let dry before painting. There is a entrance roof over it so its not totally exposed. See image for surface I am doing. My plan is to also apply a clear sealer at the end of the job to extend the life span of the product. Thanks for any tips.Name:  DSC_8842.jpg
    8,733
    482
    slab
    Any concrete that is wet and appears to be dry really isn't. Concrete is a mixture of aggregate [stone] sand [silica] and portland cement [ baked ground rock] and limestone.
    Hence it is porous.
    Pressure washing will remove some of the surfactants in the form of a whitish powder.
    To be absolutely clean it should be acid scrubbed.
    I can't see how a primer can be in an all-in-one application.
    A primer "primes" the surface for a finish coat.
    06Honda (06-13-2014)
  4. #3
    Mar 2006
    North Carolina
    1,895
    162
    I know the product your referring to Honda, it's a paint product and as a paint product it works pretty well. Power washing is a must a light solution of hydrochloric acid wash would be advisable as well. You will have to wait up to a week between washing and applying the paint to ensure the concrete is dry enough for adhesion of the paint.
    IMO stains are a much better option, they permeate into the concrete and don't have anywhere near as much "wear" paths and you can clear coat over a stain (clear coat doesn't work so well over paint).
  5. The Following User Says Thank You to pushkins For This Useful Post:
