Need help calculating garage door torsion spring
  • Need help calculating garage door torsion spring
    I have just purchased a new home and it came with an uninstalled garage door.
    The door panels came with vertical and horizontal tracks, complete spring assembly but no brackets nor cables.
    First thing I want to do is calculate what spring I should have and then calculate what spring I have.
    I'm going over there later today and I'll measure wire size, inside diameter and length.
    I calculated that the door weights 229 pounds and it is 9 feet wide and 8.125 feet high.
    I forgot to measure track radius and I'll get that later tonight.
    For now I would like to know, how can I tell which spring I need based on my values of door size, weight and track radius ?
    JF
    Read and download this. Includes free trail.
    Spring Engineering Software
      Thanks, do you know what the difference between IPPT and TIPPT is ?
        Scroll down to the bottom of this page, fill in the blanks, and it will give you an answer.
        Standard Garage Door Torsion Springs
          Nice, did see it some time ago, but didn't give a second thought.
