Thread: Lennox Elite Gas Furnace - No Heat (LEDs show "normal operation")
    Nov 2014
    I have a Lennox Elite series Gas furnace that we just tried to fire up for the first time of the fall season here in North TX. Here is the issue i am having:
    When system set to "HEAT" and Fan set to "AUTO", nothing happens at all. I can set the Fan to "ON" and it will kick in and blow air, but the furnace does not light up at all.
    I have opened the furnace door to check the Status LED lights, both Red & Green lights blink Simultaneously Slow (1 sec interval) which the sticker inside the door says "Normal Operation".
    Does anyone have any advice on how to trouble-shoot this problem? It is below freezing for the next few days and my HVAC repairman is pretty backed up, won't be here for a few days.
    Thanks.
    Outside Temp: 30 degrees
    Inside Temp: 60 degrees (and dropping)
    Lennox Elite Series Gas Furnace (do not know where to find the model number)
    Age of unit: +/- 7 years
    Here are a few photos, hopefully this helps some:
    Feb 2008
    Evansville, In
    213
    19
    Cant see your thermostat wires where they are connected at on the board, If you jumper from r terminal to w terminal the heat should come on, If it does you have a problem with the wiring or thermostat
    Nov 2013
    19
ID:	2733If all the limits and safety's are closed and you have 24 volts to W and no flash codes the board is bad.
    However if you kill power that erases the codes, you need to look through the peep hole to read the code
Tags for this Thread
