Results 1 to 5 of 5
Thread: What is happening to my walls?
  1. #1
    Join Date
    Mar 2015
    Posts
    1
    0
    Thanks Thanks Received
    0
    Thanked in
    Hello. I've been working on home repairs lately at a novice level and have noticed something happening to my walls around certain edges and railings. It is hard to describe so I've posted a few photos. It is essentially peeling off in a strip. Any idea what is happening and how difficult/involved this would be to fix? Would a repair for a crack in drywall be effective?
    Thank you
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	2769   Click image for larger version.
ID:	2768   Click image for larger version.
  2. #2
    Join Date
    Aug 2008
    Location
    Bridgton, ME
    Posts
    144
    0
    28
    Thanked in
    Looks like the bullnose corner bead is pulling away from the drywall underneath. Could be from dryness in the house causing shrinkage or from the studs drying out, or from the house settling, or from being installed poorly in the first place. The straight line crack in your 1st picture is where the edge of the bullnose flange is. In order to repair this, you'll have to remove the joint compound (mud) along the flange and re-do it. Many drywallers these days use a "lite" joint compound which is weak. I recommend using a "setting" type compound for the first layer. This stuff comes in a bag, you mix it with water, and you have about 20 minutes to use it before it hardens up like concrete. So don't use too much of it; it doesn't sand easily! Then use normal "green lid" drying mud for the other layers. Or you can remove the plastic or metal bullnose entirely and use NoCoat bullnose which is applied totally differently.
  3. #3
    Join Date
    Jul 2004
    Location
    Saint Regis Falls, NY, USA.
    Posts
    8,736
    1
    483
    Thanked in
    as long as you are going to remove the bullnose or quarter round why not go with a metal corner bead. you're gonna have to re-apply compound to the joint anyway. this way you can feather out the compound to the edge of the corner.
  4. #4
    Join Date
    Mar 2006
    Location
    North Carolina
    Posts
    1,895
    1
    162
    Thanked in
    I don't believe they make a metal bull nose corner bead.
    Join Date
    Jul 2004
    Location
    Posts
    8,736
    1
    483
    Thanked in
    ok then why not use a piece of quarter round to form the corner?
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
