Results 1 to 4 of 4
Thread: DIY Basement Wall Crack Fix?
    Apr 2015
    Question DIY Basement Wall Crack Fix?
    Hello,
    Has anyone tried the do-it-yourself (DIY) epoxy based basement wall crack repair (sealing) kits? I have some leakage during heavy rains. The DIY kits are generally less than half of a commercial company - but I'm kinda hesitant to try them out if the experience by most hasn't been very good.
    Thanks,
    Andor
    8,740
    486
    THOROSEAL or WEDGEROCK are usually used for cracks. Thoroseal is like a white-wash concrete based "paint" that seals the surface. Wedgerock is a hydraulic cement that expands as it cures. Conventional cement or portland cement shrinks as it dries. You need to make the crack larger so the wedgerock has something to grip. you mix the powder with water and is usable for about fifteen minutes before it starts to set up.
    Apr 2015
    I guess I'd rather not make the crack bigger at any point if possible...I'll look into THOROSEAL
    What about kits like the RadonSeal DIY
    8,740
    486
    I looked at the site for that radon sealant stuff. looks promising. try it! when you're finished report back here if it works. I'm sure others would like to know about it.
  5. The Following User Says Thank You to HayZee518 For This Useful Post:
    cement_head (05-06-2015)
Tags for this Thread
