Results 1 to 4 of 4
Thread: 1860 Timber Frame Exterior Bathroom Wall
    Dec 2014
    Lafargeville, NY
    39
    House was built in 1860. Re-doing the Bathroom. The exterior wall was original Horsehair Plaster, under Masonite wall board and drywall. Doing a complete gut and re-do. When I got to the lath and removed a few strips, I only had 1-1/2" of room for insulation. The lath was nailed to strips of wood, 1-1/2" thick and very wide. What I want to do is remove the lath, and the nailing strips and insulate. What kind of insulation? Rigid? Roxul? Spray foam? I drilled a hole in the wall just to see what weas under the wide boards. The wide boards are 1-1/2" thick and under them is what appears to be black tar paper. So, I can assume I am at the outer wall boards, and this wall is solid with no cavity to insulate except for the initial 1-1/2".
    I am open to ideas here.
    See attached images.Click image for larger version.
ID:	2784Click image for larger version.
    Greg
    Jan 2004
    1,698
    30
    Maybe add furring strips to the 'studs' to build it to a 3" depth? That would allow for standard insulation, but would detract from floor space. May not be an issue for just the one wall.
    8,740
    484
    what's the thickness of the studs?
    Dec 2014
    Lafargeville, NY
    39
    The plank "studs" are 1-1/2" thick
