Results 1 to 5 of 5
Thread: Ice door issue....
    Jan 2004
    1,698
    30
    Ice door issue....
    We have a GE model GSS25JFMCWW that has the ice door flapper issue. I need to order parts, but would like to get that trim ring off first to see what's needed. Last time I worked on this Dan O. sent me to a great site that had VERY helpful videos. I went there again for help, but can't find directions on trim ring removal. Shame on me, I did this before, but can't remember how it comes off! Help!!
    2,167
    80
    Arrow GE refrigerator ice dispenser flapper door
    You didn't say what issues you were dealing with but the dispenser door itself is a common failure point. You can see a video of accessing it at the following link.
    LINK > GE Refrigerator Model GSS25JFMCWW Ice Dispenser Door
    Maybe it will help?
    Appliance411.com
    Jan 2004
    1,698
    30
    You're good, Dan O. That's exactly what I needed to know. The issue is (are...) (procrastination) burned out bulb, spring not closing flapper door all the way. Door often hangs up and it gets frosted and iced. And that causes my wife to be , uh, well, 'displeased'.... This will help relieve at least SOME of that!!
    Jan 2004
    1,698
    30
    Along with the dishwasher issues, I FINALLY got around to checking the 'fridge. That flapper door does need to be replaced. And a new light bulb, too. That solenoid, though, was pretty well corroded. I cleaned and polished the solenoid pin. Glad the solenoid itself is plastic coated. It works well now. But, I suspect the reason for the corrosion is due to excess moisture in that compartment. I see there is a heater available for that area (Item:RepairClinic Item #1061807 | G.E. OEM Part #WR49X10086 ). That's a pricey item. Will that actually solve the moisture issue? Also, it says a dispenser control assembly is also needed when installing this part. What is that?
    2,167
    80
    Quote Originally Posted by mrcaptainbob
    That solenoid, though, was pretty well corroded. I cleaned and polished the solenoid pin. I suspect the reason for the corrosion is due to excess moisture in that compartment. I see there is a heater available for that area
    Excessive moisture could be just the result of the dispenser door not closing properly and the rusting possibly due to how long it was left to be that way.
    G.E. OEM Part #WR49X10086. Will that actually solve the moisture issue?
    Sorry I don't know if that is needed. If nothing else works, possibly.
    It is referring to the dispenser control circuit board. I don't know why it is required but maybe newer boards have extra terminals that are required to accept the wiring for the heater?
    LINK > GE GSS25JFMCWW Dispenser Control PCB
    Appliance411.com
