Results 1 to 5 of 5
Thread: Mid-winter howl (combustion)
  1. #1
    Join Date
    May 2014
    Posts
    24
    0
    Iíve ordered new bearings for the 422, and after taking the small cooling fan off the combustion motor I find a third rubber lube cap on the face of the bearing cap. It appears to have been full of grease, unlike the two oil caps on top. Is it likely Iíll find a second face cap when I remove the motor from the frame, and does anyone have thoughts about what to fill them with? Yourís in heat (it was -27 here Saturday), Gary
  2. #2
    Join Date
    Mar 2010
    Location
    Bethel, Alaska
    Posts
    590
    0
    I am not sure what you have there? I have never tried to use ball bearings in an older M422 that had bronze bearings. Keep us posted as to your progress. Take some pictures when you get the motor opened up. Thanks, Tom H
  3. #3
    Join Date
    May 2014
    Posts
    24
    0
    Quote Originally Posted by hawkins111 View Post
    Hi Tom, i ordered the bearings after reading one of your older forum posts, and assumed they should be 625zz that you quoted. Are the motors with oil plugs the older syle, or the newer? After loosening the motor, I see it does have a forth oil plug on the side facing the combustion fan bracket. What I took as grease is actually fiber, so I guess all four are oil ports. Iíll try that first to see if things quiet down. Thanks, GaryName:  4A17BCDA-32CD-49EE-A607-F4653B153E0D.jpg
  4. #4
    Join Date
    Mar 2010
    Location
    Bethel, Alaska
    Posts
    590
    0
    Yes they are the older style. I never tried to take an older style apart, so I'm not sure if the bearings will work. Sorry.
  5. #5
    Join Date
    May 2014
    Posts
    24
    0
    My bad. I reread, and see that the bearings are for the newer motor (okay, as I have one of those also). Thanks again
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
