Results 1 to 4 of 4
Thread: How do you remove the strainer from a sink popup assembly
    Feb 2004
    melonville, virginia.
    300
    5
     Thanks Received
    1 Post
    https://youtu.be/q34-ZQt8x9w
    i have a hasgrohe solaris i think, and i am replacing the popup assembly.
    pretty straight forward right?
    Yeah Right.
    i cant get the strainer sparated from the popup tube..
    any ideas?
    how do you hold the strainer to screw it off?
    Feb 2004
    300
    5
     Thanks Received
    1 Post
    Bump bumpity bump bump
    Feb 2004
    300
    5
     Thanks Received
    1 Post
    In this video, he says what i was looking for.....you use a hack saw to cut the tube away from the strainer-ring assembly.
    https://youtu.be/J-hJQnjneLA
  4. The Following User Says Thank You to vdotmatrix For This Useful Post:
    Mindrasect (12-24-2018)
  5. #4
    Jan 2014
    138
    13
    RIGID makes an internal pipe wrench specifically to insert into the popup that grips internally and allows you to turn it while gripping the tailpiece, it has steps to accommodate different sizes, but it is more expensive than a new popup assembly so unless you are a professional plumber it is not worth the expense.
