Results 1 to 2 of 2
Thread: troubleshoot gas wall heater- thermostat? wire?
    Jan 2007
    Hi, I have a older (15+years) cozy direct vent gas wall heater with the original manual thermostat wall control (2 wire).
    Last year, the gas valve was replaced after replacing multiple thermopiles ( pilot would go out).
    Its been working fine until last week- the pilot stays on but the gas valve doesn't "open" unless I give the valve a little whack. then the gas valve will be responsive to the thermostat for a bit then non responsive after.
    I tested the thermostat with a jumper cable- no response
    I tested the TH TH/TP on the gas valve with a jumper cable- fired up and then right after tested the thermostat- it fired up.
    Is the issue a faulty gas valve, faulty wire or thermostat?
    I hope the issue isn't the gas valve it was expensive to replace.
    Jan 2014
    138
    13
    Clean all connections to bright metal including the wires, clean thermocouple base in the gas valve and reseat it.
