I'm considering removing the leveling feet (legs) in order for it to fit under the counter. I am sure the mfg. would scream and yell to not do soAnd quite possibly void your warranty!
The legs are usually an important part of the suspension system and front load models are very hard on the suspension.
However you install it, make sure it can be easily removed for service afterward or you might be forced into major construction should service be required.If I can't remove the feet safely, I may have to rip up the travertine tiles that are underneath.
I do not know the answer to questions A - C. Sorry. I would strongly suggest you not attempt it.
www.Appliance411.com/
