30-50/250 receptacle wiring without a neutral wire for TIG welder.
  • 30-50/250 receptacle wiring without a neutral wire for TIG welder.
    I am running a 40A, 220v circuit for my TIG weld in the garage.
    I pulled a permit and was putting together a shopping list but I am stuck at the receptacle and how it is wired.
    I found (2) receptacles that only have (3) lugs two for HOT and one for the ground. NO NEUTRAL.
    I expected to find (4) lugs, red, black for HOT , white for neutral and green for ground. The following images are wired that way. Should I find a receptacle with the 4 lugs and run 8-3 romex or just run 8-2 romex.
    I don't want to cheap out or wire anything to save a buck....thanks in advance.
ID:	88046Click image for larger version
ID:	88045Click image for larger version
    I am always answering my own posts here. 240v doesnt require a neutral, two hot and a bare ground. Thats it.
