programmable thermostat
  • programmable thermostat
    Want to replace the cheap thermostat in a recently purchased home. Bought a ritetemp model 8030.
    Wiring has White, Yellow, Green and Red. New thermo has posts for W, Y, G, but has an RC and a RH. I think those are Red-Cold and Red-Hot, but what the heck do I know?
    Also, RC and RH are jumpered in the new thermo.
    Thanks for any assistance.
    Erik
    Erik,
    T-stats are tricky because of the number of different brands.
    I think RC/RH will be your common (conductor wire from equipment
    to t-stat). To be sure open the access door on your furnace/air
    handler and check the wiring diagram to make sure red is being
    used as the common. Read the wiring instructions with the t-stat
    also to determine the wiring route from equipment to t-stat. Hope
    this helps.
    Ed/metalhd2
      I'm having the same problem as you. Except my wiring has the C wire. But I only have 1 red wire coming out of the wall.
      Where do I hook it up on the rite temp? RC or RH? Should I leave RC and RH jumpered? I tried it on RC and smelled smoke after an hour.
      Thanks. Desperate.
      Steve
      Erik
        Steveb72
        Welcome to The Home Repair Forum
        Depending on the heating/cooling unit you have would depend on the wiring of the particular Thermostat..
        Check this site for the Manufactures wiring, It should explain things more clearly for you.
        16x80
