Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: JOINING DISSIMILAR PIPE ILLUSTRATED
  1. #11
    8,733
    482
    there is a fitting called a DESANKO fitting but you mention that at a home depot people are gonna look at you funny. all it is - is a beefed up plastic hub that fits into a cast iron hub and can be oakumed and leaded in place without melting. instead of using hot lead use the newer two part epoxies.
  2. #12
    Feb 2009
    Talking Drawings
    Thank you for responding back to me.It is greatly appriciated.
  3. #13
    8,733
    482
    drawings etc. are submitted by mostly the moderators of that specific section. lazypup used to be the moderator of the plumbing section as I am of the electrical section. If it helps to straighten out a situation then we will add a drawing or two.
    Reason for the bowl level not to be consistent is how soon the flapper snaps shut when the tank is flushed. sometimes it closes later or sooner and the time the tank fills as well as the bowl fill tube is later or shorter.
  4. #14
    8,733
    482
  5. #15
    Feb 2009
    Connecticut
    512
    32
    57
    Quote Originally Posted by kactuskid View Post
    Really nice drawings LazyPup. I have a guestion, is it ok to use a brass fitting to connect galvinized piping to copper instead of a dieletric union? I see this alot and figured it to be a good substitute to ensure against electrolisis.
    Brass is acceptable to join copper to galvanized. A nipple of at least 6" in length should be used.
    Brass is much closer to Galv. on the galvanic scale than copper is and makes a good transition material.
  6. #16
    Feb 2009
    Connecticut
    512
    32
    57
    Quote Originally Posted by LazyPup View Post
    Nice drawing and close to being correct.
    The all rubber Fernco is not allowed above ground an inside under many codes a banded coupling such as a Fernco Proflex should be used.
  7. #17
    Feb 2013
    Maryland
    old steel tubing soldered
    haven't seen this stuff since I was a little youngun
    thought it was chromed copper-soldered together at joints "copper" no less
    but the main tubing is thin walled steel? I know magnet sticks to it
    could not get it to solder-any clues on the age or what I'm into here?
    old house~~~
  8. #18
    8,733
    482
    tubing
    give us a picture of it.
  9. #19
    Feb 2013
    Maryland
    will snap one tomorrow on the job maybe the stamping on the tubing will show up
  10. #20
    Jun 2017
    Towson Best Garage Garage Doors Repair is a Local Garage Door Repair company specializing in Residential Garage Door Repairs and Installations as well as offering a host of additional services including, spring repair, garage maintenance, roller replacement, cable repair, opener installation and 24 hour emergency garage door repair. Our focus is primarily geared at providing exceptional customer service, we ensure that our customers receive safe, dependable and professional services rendered. All our technicians are hand picked and specially equipped with vast expertise, therefore enabling them to execute precise workmanship. Our affiliations with trusted and sought after brands, Amarr and Wayne Dalton indicates our stance on the importance of quality. We offer SAME DAY SERVICE and our skilled and knowledgeable technicians are on call 7 days a week to assist with any garage door requirements. We operate in Baltimore,MD and service surrounding areas. Call us at, (410) 344-2336 for more information.
