Thread: crumbling concrete driveway
    Aug 2003
    Bella Vista, AR, USA.
    I have a concrete driveway that is 15 months old. About 4 months ago the surface began to loosen and finally just crumble away in various spots from the size of 1-2" up to 6 x6" and it appears that the entire surface is going to follow suit.
    Any suggestions of what is causing this and the best approach to repair. So far, a law suit is all that will affect the builder.
    Jul 2003
    Milford, OH, USA.
    120
    gwagnon
    Welcome to the Home Repair Forum
    I have found some explanations to your problem...
    quote:spalled concrete can happen for a number of reasons, the concrete mixture could have been bad, no way of knowing that unless you had it tested during the pour, when it was finished, the finishers may not have done a good enough job "muddling" the Crete, which moves the rocks down into the middle,
    quote:Concrete that has been on the truck too long and poured in hot weather will spall almost every time. Too much jitterbugging will also cause spalling sometimes.
    In my own reading I believe that one possible cause is using ice melt. I found an article that might interest you if you want to tackle this yourself
    http://www.thisoldhouse.com/toh/know...218566,00.html
    If not call out a professional concrete repair company to do the work.
    When getting bids always ask for references and total costs before paying any amount of monies!
    I assume you will be tied up in litigation for quite some time trying to get anything out of your builder. As I understand it most builders only offer a 1 year warranty on a new home.
    16x80
    Jul 2002
    USA.
    570
    10
    It can also be attributed to a rolling effect of the dirt underneath. This is often caused by not properly packing the dirt before pouring the concrete.
