Frigidaire ultra quiet III Dishwasher whistling
  • Frigidaire ultra quiet III Dishwasher whistling
    I have a Frigidaire ultra quiet III Dishwasher that is generating a high frequency sound like whistling.
    - I removed the impeller cover, checking for any reason of the noise, found nothing, there are no shows of parts rubbing (it sound like that but high frequency)
    -removed the circulation motor and tested it alone, no noise
    -reinstalled it, turned it on, NO NOISE ... I thought the problem was gone... so I reassembled everything, turned it on and .. the f noise again.
    -dumped the water, tested again without water... No Noise
    -added water... the noise is there again. also I see that the pump power is lower than normal
    Unit is four years old, we use it once a week
    What is happening?
    ah.. I never dissaembled the macerator/barrel front/impeller assembly, well. I tryied but it didn't separate easy so I just left it like that (I didn't want to breake it)
    Ideas?
    Thanks, Yes, Thanks
    quote:Frigidaire ultra quiet III Dishwasher
    I'm afraid that is not enough information to determine which Frigidaire dishwasher design you have, they have had numerous different ones over the years. What is needed is its *model number* as written on the appliance's identification tag.
    You can find tips for locating the model and serial number tag on your appliances in the 'Repair Parts' section of my web site linked below.
    quote:generating a high frequency sound like whistling... also I see that the pump power is lower than normal
    That might be caused by a restriction in water flow. Maybe look for something blocking some of the ports of the spray arm(s)?
      Thank you for answering!!!!
      the model is frt22tseb1 according to the warranty card
      According to the service data sheet that was close to the timerinside the control panel is model FDB636 or FDB679 please let me know if this info is enough. The attached file was taken from the service data sheet
      Thanks, Yes, Thanks
        I used your link to know where the tag is and found the model number
        is FDB679GFC2
        About the spray arms... the sound is there with the arms in or out
        Thanks, Yes, Thanks
          You know what? I guess I saw some dust over the black shaft of the pump motor, the sound could be friction between the shaft and the impeller.
          I have to check more job offers on those job searchers because no job no money for home
          probably tomorrow will dissassemble the system again and check
          but friends: do not stop sending me probable solutions
            That happens to be the model number of a Frigidaire top-freezer refrigerator. BTW. That is exactly the reason we prefer that information to be obtained directly off the appliance's model and serial number tag so there are no errors.
            quote:the [real] model number is FDB679GFC2... I guess I saw some dust over the black shaft of the pump motor, the sound could be friction between the shaft and the impeller.
            I think that may be a good possibility although I don't know what would cause it on that pump and motor design, sorry. It will likely have to be looked into to determine the cause.
              Hello friends
              I disassembled that section (impeller -barrel- motor again but no dust this time, no idea what happens
              I am puzzled because the shaft does not have the hole and thread for the screw that secures the impeller, so it looks that the impeller is connected to one of those little pieces like the "barrel front" do you know how to get more information on how to disassemble that section? (barrel rear-macerator-barrel front). did you see the graph I attached? Please do not give Up. do you know if frigidaire could give me imformation?
                quote:do you know if frigidaire could give me information?
                Frigidaire does have a service manual for that design of dishwasher (see the following link). I very much doubt they'd give you a copy or tell you how to service your dishwasher.
                LINK > Frigidaire 'Precision Wash' Dishwasher Service Manual
                  I checked again the dishwasher and found that the white plastic part (barrel rear) where the motor shaft enters, has a two fisures so I believe the reason of the noise is that the barrel is sliping over the shaft.
                  I am attaching three pictures, I want to know where are the splines? I see the brown straight lines on the hole where the shaft enters (see the shaft picture .. no splines) .. which is the system to keep the shaft and the plastic stuff ( barrel/macerator/impeller)together?, see that the shaft does not have any hole where the lock screw enters.
                  Any coments?
                  German
                  The pictures are at:
                  Picture 1
                  Picture 2
                  Picture 3
                  regards
                  Last edited by Dan O.; 11-09-2008, 02:58 AM. Reason: Pictures no longer available except attachment
                    quote:I want to know where are the splines?
                    I think you found where the "dust over the black shaft of the pump motor" came from. I've never seen a dishwasher motor shaft worn that completely before. I think it's time for a new motor.
                    LINK > Frigidaire FDB679GFC2 Pump Motor
                    BTW. How long have you been experiencing the noise?
                      Hey I forgot to say thanks, I bought the Dishwasher motor, it came with everything included the 15 inches diameter plastic base (why?), the motor, gaskets etc and worked (of course) I think it is expensive $130
                      Now is the freaking timer motor assembly... it locks sometimes in one place it is exacltly 180 degres from the start position...Grrrr
                        Did we ask how old this dishwasher is? I am thinking in terms of how much money you should put into a DW if it is more than 7 or 8 years.
                        As to why you had to purchase a large assembly, as opposed just the motor: two reasons.
                        Service would be too expensive if customers had to pay the labor cost of disassembly and repair to the small part level. AND, a service man is not going to warrant a pump assembly full of old parts while just replacing the motor.
                          That kit replaces several different pump motors from different manufactures which have been used in production. In order to install the current motor, a new housing is usually required as well. They ship 2 housings because models could use one or the other depending on the dishwasher's features.
                          The kit was made available due to complaints from field service depots which before then had to stock 3-4 different motors and a bunch of different housings in order to complete repair jobs on the first trip. A single motor kit that would fit all, reduced servicer's inventory making it easier for repairs to be completed quickly which is more cost effective to the servicer and preferred by customers.
                          LINK > Frigidaire D/W Pump & Motor Kit
                          it locks sometimes in one place it is exactly 180 degrees from the start position.
                          Unless something fell into the pump and is jamming it (unlikely IMO), I can't think of anything besides a defective motor which would cause it.
                          It's probably not what you want to hear but the replacement motor should be warranted for 1-year so you'll likely need to order and install a replacement and return that one.
                          Kinda late for that now (seeing the part has been purchased and all) but that model only looks to be a 2000 or later. I could tell for sure with its serial number. Being that it's a non-electronic control model, there isn't a lot to go wrong with that particular design and it's new enough that it should be reasonably thrifty with water consumption. I don't believe just a motor replacement is unreasonable unless it was a very bottom of the line model and/or there were other problems like the racks rusting, timer not advancing or malfunctioning, etc.
                            Impeller/shaft disassembly
                            I've just uncovered the same problem with a slipping shaft, complete with the same cracks in the barrel as you picture. Note the impeller clips onto the shaft, the stainless screw on the end keeps the clip from compressing. Pinch the end of the shaft with fingertips or small pliers and the impeller will slid off and the whole unit can be disassembled.
                            I've yet to find if I can order just the shaft, everything I've found on the web doesn't break this part out. I've a good appliance parts store in town that I hope can help me with this. I'll relay any info I find. An apparent weak design that likely causes lots of problems. The unit hasn't been cleaning too well lately, probably has been slipping to some degree for awhile.
                            BTW, I do see the splines on the motor shaft in the picture, they're just very close to the motor housing.
