Blower control
  • Blower control
    I have a 16 year old gas furnace. I replaced the inducer motor assembly and now the furnace will ignite, the blower will come on for about 8 seconds and then shut off. It will do this 4 times until the temperature increases 1 degree on the thermostat. It's a 3 setting control. 50 to 150 and it doesn't seem to matter where I set the controls. Any suggestions?
    Does this behavior occur when the thermost is set at a nornmal room temperature of say 68-75 degrees?
    Where is your furnace? Is it in some cold area where there is also a cold air return grill in this cold area?
    Do you have a fan SWITCH, or does yours work off one of those solid state timer boards? IF you have a switch... you wouldn't happen to have the rectangular approx. 2 x 3 inch one made by Honeywell, that has the numbers on the dial, under the cover, that you can look at, do you?
      Not quite clear what you are talking about - what is a 3 setting control? Why did you replace the inducer motor? What was your original problem??
      Brandon
        This occurs at normal temperature setting of 75.
        The furnace is in a closet in the lower level of the house and does have a cold air return.
        The blower control is similar to what you mention. It has a silver dial with 3 tabs you can adjust from 50 to 150. Off, off, on.
        The inducer motor began making a noise and eventually siezed up.
        The filter is clean.
          It sounds like a safety switch problem - at this point I think calling a tech out would be money well spent.
          Brandon
