GE Heavy Duty 18
  • GE Heavy Duty 18
    Hey
    This dryer owes me nothing really, but if I can fix it i will naturally. Just the other day the dryer began shutting off after about 5 seconds of opperation. I have tried all the settings, but it does this no matter what, as if the timer is stuck on 5 seconds or something. Can I buy parts for this? Is there a fix? Garbage? The rest of the information is as follows, and it is about 25 years old (young?)
    Model#DDE8200PBCWH
    Serial # VP206945A
    120/240V
    3Wire
    60 Hz
    5600W
    24 Amps
    Thanks!
    ** as if the timer is stuck on 5 seconds or something **
    You mean the timer never moves?
    ** the dryer began shutting off after about 5 seconds of opperation. **
    As opposed to only running *while* the start button is held down??
    ** Can I buy parts for this? **
    Probably... depending on the part which is needed.
    ** Is there a fix? **
    I'm sure there is but first someone will need to determine the actual cause first.
