Frozen water line from condensation pump
  • Frozen water line from condensation pump
    I have cut the half inch clear plastic line to three inches as it passes thru my foundation. I have also bent it at a 45 degree angle so the water drips out of it. Any suggestions. Thank you, Kim
    If it's discharging outside and it's above the frost line then there's not much you can do to keep a 1/2" line from freezing. You'll need to either install a larger diameter pipe to the outside, like 3 or 4" size or if possible try and redirect this drain line to an inside floor drain or perhaps a laundry tub
