Results 1 to 5 of 5
Thread: Ge ice maker will not dump
    Oct 2008
    Power went out for 8 days during Hurricane IKE. Plugged Fridge into generator after 3 days. Made 1 ice dump. Will not dump Ice now. Thawed it out and it worked 1 time agian. Any ideas????
    2,166
    More information required
    We will need the appliance's model number to look up which type of icemaker is used in it. You can find tips for locating the model and serial number identification tag on your appliances at the following link:
    LINK > Model Number Tag Search
    ** Thawed it out **
    Thawed what out exactly??
    Oct 2008
    Dan O...
    GSL25JFPH BS
    TG219364
    I thawed the frozen ice cubes out that were in the tray. It then filled them and dumped the cubes one time. It will then fill the trays & freeze but will not dump. Thanks for any help on this.
    2,166
    Unhappy Electronic icemaker
    Quote Originally Posted by TREY09
    [GE refrigerator model] GSL25JFPH BS
    That fridge model uses GE's electronically controlled icemaker (see the following link).
    LINK > GE GSL25JFPHBS Icemaker Asm.
    There should only be two things that could cause that symptom with that icemaker design;
    1. The icemaker mold isn't getting cold enough for the icemaker's electronic control to detect ice has been made.
    2. The icemaker is defective and not detecting the frozen cubes in order to initiate a harvest (aka dump).
    Make sure there is nothing obstructing air flow around the icemaker and that the freezer compartment is cooling properly. It should be +5°F to -5°F not just below 32°F where water freezes. If those are not the problem, the icemaker likely needs to be replaced.
    On GE's electronically controlled icemakers there are no service parts available at all. If defective the icemaker has to be replaced.
    Oct 2008
    Thanks for the help...
