Adjust Touch n go 100
  • Adjust Touch n go 100
    I have a touch'n go 100 garage door opener, and now that the cold weather is here, it doesn't always want to go down. I know that I've had the renegades from Overhead Door out to adjust it in the past, and I really don't want to spend the $75 for a service call again. Does anyone have a clue on how to adjust this?
    sensitivity settining?
    look for a screw near the top of the motor unit that has a spring around it marked by the word close, or down. If you turn the screw to make that spring smaller you will enable the motor to work harder and push the door all the way down.
    ryan
      Step one
      I am assuming that I have to remove the cover first. I hadn't taken the liberty yet. Thanks for the info.
