Results 1 to 6 of 6
Thread: Reparing Hole in Garbage Disposal
    Nov 2008
    Hello! I recently discovered a small (say about the size of the tip of a pen) hole in the side of my disposal. Of course, water is leaking out every time that side of the sink is used. Until we can get a new disposal, is there anything I can put on there for the time being? Maybe some plumber's putty or waterproof joint tape?
    Thanks in advance!
    Mar 2006
    North Carolina
    1,895
    You might be able to use some liquid weld, basically it's a two part epoxy that you mix together and then apply over the hole, it can be used in engine blocks to repair stripped threads and then re tapped, so I cannot see why you could use it as a temporary fix on the disposal.
    It's available at most big box stores and auto shops , comes under different names like Jen Weld, Epoxy Weld...etc.
    Nov 2008
    Thanks, Pushkins! I'll give it a shot.
    Dec 2003
    eugene, oregon, USA.
    47
    marine weld is another option, either way it must be applied to a clean dry surface, and for best results make sure it gets good penitration of the hole, even if it means making the hole a little larger.
    aquarium silicone can also be used for a short term fix.TAZ
    nuthing like being woken up at 12:AM to unstop some one elses toilet.
    Nov 2005
    136
    Epoxy putty/Home Depot
    Oatey No. 31270D, 4 Ounce Epoxy Putty - 31270 at The Home Depot
    Comes in two-part tubes. Mix the parts together with gloved hands and apply it. Hardens in minutes.
    Dan
    Jul 2007
    90
    Let's get real. If the disposal is old enough for a hole to have corroded through the body, then the grind chamber is likely in similar degraded condition. The likelihood is that you are putting a lot of very coarsely shredded food into the drain line. Clog to follow soon.
    Let's say you have a typical Badger 5 model. It has ( had ) a 2 year warranty, and a reasonable life expectancy of about 5 years. Where are you in that picture?
