Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: whirlpool gas dryer won't ignite
    Feb 2009
    8
    Hello, I have a gas dryer, whirlpool, model # LGC8858EQ1 which was working fine until today....., when the wife said that it stopped! Of course when I checked it ...it did not actually 'stop', it tumbles, it just won't ignite or light up, as seen through the access peephole on the lower front,...My ??? is...., how do I access the components to check it out, and where do I go from there??
    Thanks, in advance for any assistance!
    2,166
    Arrow Clarification needed
    Quote Originally Posted by bobp
    whirlpool gas dryer model # LGC8858EQ1. it tumbles, it just won't ignite or light up, as seen through the access peephole on the lower front
    Please be more specific. Is the ignitor glowing when it should be heating but just not producing a gas flame (ie 'igniting') or no ignitor glow nor flame??
    On models without a separate lower access panel below the door, the whole dryer front panel usually needs to be removed to access internal components. While for the electric version of your dryer, the disassembly instructions about 'drum rollers' at the following link might give you some ideas on opening yours.
    LINK > Sears and Whirlpool Electric Dryer
    Feb 2009
    8
    Dan O. thanks for the reply...the ignitor is not glowing or even a flicker, in response to the link, I did not see where to view a disassembly breakdown, or maybe I overlooked it, any ideas on how to see an illustration?
    Thanks.
    2,166
    I suggested the disassembly instructions about 'drum rollers' at the previous link might give you some ideas on opening yours.
    This text on the page: > ... you may have to replace the drum rollers.
    JFYI
    Feb 2009
    8
    Dan O. the link for the disassembly helped, I have it apart and I can't seem to find the link which guides one through the troubleshoot tests for the ignitor not igniting.
    Feb 2009
    8
    Okay, I have a 110 volt tester that beeps and flashes when it senses 110 volts, I start the dryer, I have pwr to motor, motor works fine, w/ frt. cover off, I have no pwr at all to the ignitor or any of the wires on that side of the dryer. I then went to the top, I have pwr to control panel, until I switch to 'heavy' heat mode and then the other wire at end of panel, near where there power supply goes to panel goes dead, switch to med., pwr is back, but still not to lower area where ignitor and other components are...
    Now I get really lost...what would be my next thing to check?
    Again ...thanks for the help!
    2,166
    I never said there was one (and there isn't since I said it was for an electric equivalent of your dryer). I only suggested the previous link to try to help you open the appliance up, which is what you requested.
    You can however read general information on how common gas dryer burners operate at this link:
    LINK > Generic Gas Dryer Burner Operation
    I do not know how you are testing.
    If 120 volts is not getting to the whole burner assembly, any component in the wiring circuit to it will need to be checked for continuity (not power!) to see if they're electrically open, stopping its power supply and preventing its operation.
    LINK > How do I test for continuity?
    Possibilities on your model for power not getting to the whole burner are the heat contact of the timer, the high limit thermostat, the cycling thermostat, the thermal fuse on the blower housing and even two contacts on the motor switch. Defective wiring can't be ruled out either.
    LINK > LGC8858EQ1 High Limit Thermostat
    LINK > LGC8858EQ1 Cycling Thermostat
    LINK > LGC8858EQ1 Thermal Fuse
    Besides power not getting to the whole burner, just a defective ignitor would stop its glowing but wouldn't prevent power from getting to the burner as a whole.
    If you want to consider a repair manual, the one available at the following link covers both Whirlpool gas and electric dryers.
    LINK > Whirlpool/Kenmore Gas/Electric Dryer Repair Manual
    JFYI
    Feb 2009
    8
    Thanks, I saw link while searching the forum yesterday and 'I' couldn't get it back again, I did not mean for it to come across that you mentioned it, I will check the links tomorrow and get back to you, thanks again
    Feb 2009
    8
    Dan O. thanks for the assistance, I checked the continuity, and found that the thermostat fuse was bad, I replaced it and everythings okay, thanks again!
    2,166
    Exclamation More checking to do!
    The thermal fuse??
    If so, it opening is usually a sign of a problem in the dryer, a warning! It is designed to open when the dryer overheats to try to prevent a fire.
    A venting problem (see the following link) is the most common cause of a thermal fuse failure which should not be taken lightly nor put off.
    LINK > How long can my dryer vent be?
    I *strongly* suggest someone painstakingly inspect and/or clean the dryer's whole venting *all the way from the dryer to the outdoors*. The life you save may be your own.
