Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Whirlpool washer wont spin
    Mar 2009
    11
    i have a whirlpool washer model #wtw57esvw. It wont spin so i change the motor coupling and it began to work.i tried washing a load of clothes but began to smell something burning and the washer completely stopped from washing or draining. It will fill with water and thats that. Please help.
    2,166
    whirlpool washer won't spin so i change the motor coupling
    The motor coupler would usually only be the problem if both spin AND agitation failed. It would affect both.
    ...but began to smell something burning and the washer completely stopped from washing or draining.
    ... and spinning I assume?
    If so, all those functions are the responsibility of the main washer motor. The burning smell might be coming from it or even any electrical part (timer, wiring, etc.) in its circuit. Tracing the actual origin of the odor will likely be required to determine which.
    Mar 2009
    11
    How do i check the wiring
    2,166
    Quote Originally Posted by bush mechanic
    Have you isolated the origin of the odor yet?
    The wiring can be inspected for visible signs of discoloration, burning or melting. Areas of particular interest would be any connectors in it.
    if you have a basic diagram of the motor terminations you can make a test jumper. I made one up for a maytag washer motor. two wires are neutral two wires are 120 hot. one set goes to the startwinding the other the run winding. the two windings are electrically isolated from each other. some may share a common neutral. this is why I say look at the motor wiring diagram.
    Mar 2009
    11
    I just went back to the washer plugged it in and it filled with water and started to wash but it wont dispense the water out of the machine and i began to smell the burning so i turned it off and unplugged it. This is strange because it only filled with water now it washed but didn't let the water out. so that means the motor is working have to check the wiring but i dont have any meter.
    Mar 2009
    11
    I just was looking at the washer and tried to move the agitator by hand but it is very hard to move is this normal.
    2,166
    I tried to move the agitator by hand but it is very hard to move. is this normal?
    Yes, the very bottom of it anyway. It is attached to the gearing inside the transmission.
    Mar 2009
    11
    I made another check of the washer and i noticed that the motor looked as if it was overheating because i saw some plastic looked like it melted on the coil so that is the cause of the burning odor.there were no other wires showing burns. Why did the washer fill and wash but stopped when it was time to dispense the water before the rinse cycle. Could the lid switch be the cause of the motor heating up?
    2,166
    No.
    Why did the washer fill and wash but stop when it was time to [drain] the water
    Maybe that just happens to be when the motor decided to fail?
    Was the washer trying to spin at the same time as it was draining? That might do it too. On your model the washer should drain for 1-2 minutes before pausing briefly and only then attempt to spin.
    Will the washer agitate any longer? If the motor is shot, it shouldn't.
    LINK > Whirlpool WTW57ESVW0 Washer Motor
