Thread: Trane A/C blower fan won't shut off.
    Apr 2009
    Unhappy Trane A/C blower fan won't shut off.
    I have a home ac unit (Trane), about 2 tons,. The blower fan will not turn off once it starts. Even if I turn the thermostat to the off position. I have to turn off the circuit breaker to stop it. When I turn the breaker back on the fan will stay off until I restart it at the thermostat but will then stay on again. I have tried a different thermostat unit. Fred B
    Sep 2006
    IL
    168
    There is a fan relay that is controlled by your stat, it could be sticking.
    Is it beer thirty??
  3. The Following User Says Thank You to Java_Bob For This Useful Post:
    Fred B (04-04-2009)
  4. #3
    Feb 2008
    Evansville, In
    213
    How old is your furnance, the older ones had a fan high temperature limit switch that when it failed would sometimes cause the problem you are describing
  5. The Following User Says Thank You to jnaas2 For This Useful Post:
    Fred B (04-04-2009)
