Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: New 18 SEER ....same KWH usage?
  1. #11
    Join Date
    Jul 2004
    Location
    Saint Regis Falls, NY, USA.
    Posts
    8,743
    1
    Thanks Thanks Received
    486
    Thanked in
    Seasonal Energy Efficiency Ratio (SEER), is most commonly used to measure the efficiency of a central air conditioner. It measures how efficiently a cooling system will operate over an entire season. The higher the SEER, the more efficient the air conditioner. Technically speaking, SEER is a measure of equipment the total cooling of a central air conditioner or heat pump (in Btu) during the normal cooling season as compared to the total electric energy input (in watt-hours) consumed during the same period
    Energy Efficiency Ratio (EER) is a measure of how efficiently a cooling system will operate when the outdoor temperature is at a specific level (95oF). In technical terms, EER is the steady-state rate of heat energy removal (i.e. cooling capacity) by the product measured in Btuh divided by the steady-state rate of energy input to the product measured in watts. This ratio is expressed in Btuh/watt. The higher the EER, the more efficient the air conditioner.
    Both SEER and EER are included in the ENERGY STAR specification because each rating indicates the energy efficiency of the product under different operating modes. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations. Both ratings are important when choosing a product.
    Heat Seasonal Performance Factor (HSPF) is the most commonly used measure of a heat pumps heating efficiency. It represents the total heating output of a heat pump (including supplementary electric heat) during the normal heating season (in Btu) as compared to the total electricity consumed (in watt-hours) during the same period. HSPF is based on tests performed in accordance with AHRI 210/240 (formerly ARI Standard 210/240)1.
  2. #12
    Join Date
    Dec 2008
    Posts
    17
    0
    0
    Thanked in
    Reversing Valve was Sticking. Amana replaced entire system this past winter with 18 SEER THREE ton (From 4). I did a manual J and MADE them put 3 tons in, even though they said it was too small. (In another life I was a residential energy auditor) Heats and Cools just fine, and $$$ has been reduced quite a bit.
    CASE CLOSED!
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
