Monjtor
  • Monjtor
    I have a monitor 41 heater the problem is ,i unhooked the fuel line that goes to the pot i put the fuel line in a bottle and turn on the heater . No fuel and the pump made no noise,have plenty of fuel going into the back of the heater and the filter is clear ,,,,,,,,,,,,,bad fuel pump?
    use a multimeter with the dial set to 200 volts. you should read 120 volts pulsating. the output comes off the tristan pump controller. if your have to get a new one, the controller and pump come as a set.
