Thermador Stove Top Igniter Problem
  • Thermador Stove Top Igniter Problem
    Best I can tel by reading upside down and NOT being able too find my numerous pairs of glasses its model # SGSCV36GW serial 95030393. In order to light 3 of the 4 burners I have to do it manually.
    I removed all the igniters and cleaned them but still NG.
    Did some looking around at parts and could it be the Spark module kit? If it is where is it? Any idea on a manual on this stove top?
    Thx
    I have to [light 3 of the 4 burners] manually
    Do they spark when turned on?
    Any sounds when turned on?
    I'm sure that could be one possibility, yes.
    I am not familiar with that cooktop's actual constructions but a problem in the burner ignition switches, the wiring from them to the spark module, the wiring from the spark module to the spark electrodes at the burners and a problem with the spark electrodes themselves could likely also cause ignition problems.
    You could ask Thermador if one is available for purchase.
      I'm sure [the spark module] could be one possibility, yes.
      I only get one to spark even when I switched them around. I didn't mark which one did spark before I cleaned and moved them.
      I did find a spark module here:
      Part Details - BOSCH Spark module kit, part number: AP2836547
        I'm wondering if its just better of replacing the whole unit but my concern is matching up the down draft exhaust. Will anything new match up or am I looking at a real PITA job.
        BTW the current unit is about 15+ yo. Not sure its worth putting $ into it.
          About the only thing that would match up exactly (or very close) would likely be another Thermador model. You'd have to check with them whether they still make a model of close enough design. Otherwise you'll likely have to deal with the venting... whatever it takes.
          But before replacing it, if you can't isolate the cause yourself I suggest you call in a professional. It would likely be less costly (and less headaches) than replacing it.
          PS. I suggest a Thermador *factory authorized* service depot if you call for service.
            Called thermador and they have no direct replacement. So either cabinet or countertop modifications will have to be made.
              Got another chance to take a look at the stove. The actual problem is the igniters are loose and are in contact with the burners. There are supposed to be small O rings that hold the igniters in place.
              I loosened/removed the venturi but still can't get the drip plate off, tried gently prying it off with a plastic scraper but no go.
                Glad to hear you might have isolated the problem but unfortunately I am not familiar with your appliance design to offer any service tips.
                  Thx Dan,
                  I'll figure it out eventually.
