Results 1 to 6 of 6
Thread: Painting latex over bondo
    Jan 2009
    22
    5
    I bought a bunch of crown moulding and as I put it up I saw 2 pcs had some nice junks in them. In the past I have always used car bondo to patch those types of problems. My question is, once I use the bondo can those areas be painted over with a regular latex paint? The reason I use car bondo is because wood filler never would hold in the damaged areas.
    have you ever tried DURHAM'S water putty? This stuff is a pale yellow powder that mixes with water. It can be drilled, tapped like a machine screw and stained. For areas thicker than 1/4 inch allow a 24 hr cure time.
    May 2007
    109
    Quote Originally Posted by bja1016 View Post
    I have never seen any sort of paint that had a problem with bondo. About the only negative property I ever found with the stuff is its ability to suck up water from the back side and blister the paint from behind. Not exactly a problem you find in a house. The other thing about bondo is how cheap it is for a fairly solid repair that will keep in the can for years or until the next fender gets crunched.
    if it is used for a car repair, it's usually primed with a gray varnish primer. never seen it covered with any latex product, but I imagine it could be.
    Durham water putty would work best for wood areas. It's porous enough to accept latex and oil based primers.
    Mar 2006
    North Carolina
    1,895
    Sure hope the OP found a solution before now, it's been almost 2 years.
    Driz was the guy that opened it again!
