Results 1 to 2 of 2
Thread: Shower caulk turns yellow and collects dirt
    Mar 2008
    142
    We re-caulked the sliding glass door frame last summer. It is leaking again and turned yellow.
    Is there something that works and doesn't pick up dirt and grime?
    Thank you.
    Dec 2009
    NW Arkansas
    59
    For those applications, I use 100% silicone caulk. Don't cheap out on it, you don't want to repeat this for as long as possible.
    Regular kitchen and bath caulk will not hold up very long in a shower. Make sure you remove all traces of the old caulk before you put in the silicone. Rub it down with some alcohol and let that dry for a few minutes.
    If you've not used 100% silicone before, you may want to use some tape and mask off about 1/8" on either side of the joint. After you put the silicone in and smooth it out, remove the tape immediately.
    Should last for a few years, provided water isn't getting behind it from some other location.
