Corning RC-100 Range_Self Clean out
  • Corning RC-100 Range_Self Clean out
    Probably a lost cause, but golly we like this range and she's still in excellent shape except the 'Self Clean' function's no longer operable. I've been told parts are not out there but was hoping what I need may be generic. When a person rotates the Oven Temperature Control to the 'Clean' position, you would normally hear the selenoid click (locking door) and the 'Clean' light would come on........niether of these occur.
    Any suggestions welcome......otherwise my wife has told me I'm in charge of the 'Easy Off' detail.
    TIA.
    Investigation needed
    When a person rotates the Oven Temperature Control to the 'Clean' position, you would normally hear the solenoid click (locking door) and the 'Clean' light would come on. neither of these occur. Any suggestions
    Someone would likely need to look into whether it was the control that was at fault or maybe just the solenoid or its wiring.
    I've been told parts are [no longer available] but was hoping what I need may be generic.
    I have my doubts if it is any kind of control you need but if you provide all the numbers found on the failed component (maybe along with pictures), we'll see if we can trace them. Also, depending on exactly what component is needed there is a chance (although possibly just slim) that it might be able to be repaired.
      Thanks Dan......I'll try to open up the control panal to at least have a look-see at the switch & test continuity there.....if I that turns up anything, will take pics & numbers.
        Troy was going to try to help me upload the 3 pics for this post as the site is not allowing me.
        Anyway......if he's successful I have a PDF of the wiring schematic as well as 2 pics
        My 1st thought was the solenoid but last week, out of the blue, that solenoid kicked over and locked the front door.....I've now disconnected it.
        The panel rotary switch is the one on the right (viewed from back).
        Attached is wiring & 2 pics
          I don't know how that is going to help find the cause. Someone will likely have to actually investigate the appliance itself. There's not a lot that can be done from afar to try to trace the problem.
            OK fine......just thought the schematic might lead to a suggest of where to check continuity. Thanks anyway.
              My thought are there is a small microswitch or an extra contact on your oven control that actuates the clean portion and lock up solenoid.
                Images
                Here's the images he was referring to:
                by the way I had to resize them to get it to work, they were huge! File sizes are limited on this server.
                Try
                  Originally posted by Troy
                  Here's the images he was referring to. by the way I had to resize them to get it to work, they were huge!
                  Unfortunately the wiring diagram at that size is unreadable.
                  Someone would need to trace the wiring route from the solenoid and test everything in the electrical path. If the wiring diagram shows the switching of the switch contacts, the terminals on the switch for the lock solenoid would have to be isolated and then tested.
                    You have simple Adobe Reader?.....that PDF can easily be cranked to 400%.....has good res.....I can read all.
                    Yep.....I am tearing into this again this weekend....will try to trace to see what stands between nothing and engaging clean.....still think it may be something simple since all other op is good.
                      Too bad a link to the PDF wasn't supplied, just a resized JPG image. That was apparently due to the large file size of the original as Troy stated. (Not that it would likely to have helped anyway)
                      JFYI
                        Pretty hard to get the file (readable) down to 19KB (apparently the limet).....but thanks for trying to help anyway......appreciated.
                          19KB apparently the limet
                          The limit for posting here. Upload it elsewhere and then just link to it from here. But as I said, it likely won't help us to tell you were the problem is regardless.
