Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Whirlpool Dryer problem
    Nov 2010
    9
    I have a whirlpool dryer model # - LER4634JQ1. I have had the dryer about 8 years. Lately it has been taking a long time to dry clothes. My wife dried some normal things (t-shirts, undergarments, etc.) for 40 minutes and said they were almost like you had just put them in the dryer. My first thought would be the heating element but I don't really know anything about dryer repair. Could somebody lead me in the right direction? Thanks for any help.
    Oct 2010
    New England
    135
    6
    9
    dryer repair
    how handy are you basic hand tools ? multimeter ?
    Oct 2010
    New England
    135
    6
    9
    dryer repair
    i must advise first if you have no electrical experience you may want to possibly find a friend that does to help you or call a service person
    if you go to sears darts direct website and enter your dryer model # you should be able to find a good printable schematic of the bulkhead so you can get an idea of what you will be looking at when you remove the panels.
    somewhere i have a dvd showing complete service and diagnostic on that style dryer. ill look for it and you can get back to me if you want to do it yourself.
  4. The Following User Says Thank You to dfitz3390 For This Useful Post:
    LoraStar (11-16-2010)
  5. #4
    2,167
    80
    Exclamation Check and/or *thoroughly* clean venting first
    whirlpool dryer model LER4634JQ1. Lately it has been taking a long time to dry clothes.
    Heating elements most often either work or they don't. If the dryer is heating at all I would suggest you start with its venting (see the following link).
    LINK > How long can my dryer vent be?
  6. The Following User Says Thank You to Dan O. For This Useful Post:
  7. #5
    Nov 2010
    7
    My friend has the same problem! Thanks, for the help, guys!
  8. #6
    Nov 2010
    9
    I'm pretty handy at most things except electrical. Don't know alot about it but do have some friends I could ask. I would prefer to do it myself. I'll start by checking my venting to make sure all is clear there.
  9. #7
    Oct 2010
    New England
    135
    6
    9
    dryer
    i assumed you had checked that my fault for assuming. will be glad to help anyway i can
  10. #8
    Nov 2010
    9
    OK. Checked the venting and it seems to be ok. I checked it at the outside and took off the vent from back of the dryer and made sure they were both clear. Also pulled out the lint screen and made sure the inside tube looked ok. What would you suggest i check next. By the way thanks for all your help!
  11. #9
    2,167
    80
    Question Is it heating?
    Is the dryer at least heating some?
    Was the venting totally clear from one end to the other?
    Did you try the test suggested at the link I supplied of running a load with the vent totally removed to see if drying improves? (only applicable if the dryer is heating at least some)
    If the venting really isn't the problem, next would often be inspecting the heating element for a short to ground. The heating coil (looks like a spring) should be intact from one end to the other and none of it touching ground (the metal housing).
    LINK > Whirlpool LER4634JQ1 Heating Element
    If the dryer is not heating at all there are several of other components that will need to be checked as well.
    LINK > Can anybody tell me the most likely scenarios for lack of heat in an electric dryer?
  12. #10
    Nov 2010
    9
    Yes it is still heating but takes about twice as long to get things dry and it used to.
Tags for this Thread
