30yr old oil furnace stack control repair
  • 30yr old oil furnace stack control repair
    i have a UL 85-ds oil furnace, with a mercoid pyratherm type jm stack control unit. it was installed in 1971 (i think).
    my problem is that the aperture arm disconnecting the transformer (i think i'm using the right terminology) has to be manually toggled on or off.
    when i google it all i come up with are archived canadian pdf's 1903-1920something
    here's some pictures of what it is:
    OFF
    transformer in down position
    TO TURN ON
    transformer in up position, pushing down on aperture arm
    TO TURN OFF
    rotating the thermo rod clockwise to disengage aperture arm
    so basically the thermostat doesnt control the heat, i have to manually engage/disengage the stack control to turn it off/on.
    anyone know what is/isnt happening?
    need more pics?
    EDIT: I CANT POST PICTURES UNTIL I HAVE MADE 15 POSTS
    maybe i can link to it this way
    go to photobucket.com
    search for user jasongregg
    click the stack control album
      OFF
      TO TURN ON
      TO TURN OFF
      need more pics?
      i am not sure i know what you have but if you want to send me a few pic. i will take a look. Later Paul paulm989@hotmail.com
        did you get the pictures?
          No i did not get any pic. in my email. I do not do photobucket, facebook or any of those things. Paul
            oh, ok.
            well anyways i fixed it.
            it wasnt the stack control, it wasnt a thermocouple (someone told me to replace it, but after tearing the whole furnace apart, i later read there is no thermocouple in an oil furnace.
            so after i got everything back together, someone else told me to just take the (two) wires from the thermostat and touch them, to see if the furnace turns on.
            i did and it did.
            so then a bit later i ahd the bright idea of replacing the batteries in the thermostat, i did, and now it works.
